why no gain??
The reason you wouldn't SEE gains would either be from worse weather, or that they are so negligible that you wouldn't regardless.
What was the DA on both of those track days? I bet they were slightly better the first day.
I agree with Fergy almost 100%
He already had a cam though that was doing .525 on stock heads. From my research, the heads don't flow anything different from .450 and up lift. And if they do, it's only 3 or so CFM.
as for the OP you may not have seen a gain variables can affect this easily. i feel you will see a gainin the longrun!
