Head gasket Tests? Help...
Old Oct 23, 2008 | 09:45 PM
lemons12's Avatar
water out coming out of tail pipe....
also take a dollar bill and put it flat up against the tail pipe while car is in park... it should steadily blow the dollar bill away from it, if the head gasket is blown every once in a while it will suck the dollar bill back towards the tail pipe..
Old Oct 23, 2008 | 10:26 PM
xx_ED_xx's Avatar
Napa sells this kit for testing coolant for blown head gaskets
If it detects combustion gas in coolant it will change the color of the dye.
Its pretty handy and it works and all you have to do is take the radiator cap off to do it.
Old Oct 23, 2008 | 10:43 PM
2XR95Z28's Avatar
Thank you very much for all the help guys, i will try those two things tomorrow, (dollar bill and napa test) Any other test are appreciated, tryin everything i can to not have to pull the head and compression test is my last test cause i mise well pull the damn head lol.
