alternator question
My other question is this a good alternator to buy?
http://www.partsamerica.com/productd...ype=11&PTSet=A
thanks everyone
So the short: PS pump is RIGHT under the alternator, so it's most likely that (the PS) that is whining. Dying alternators generally make a LOVELY screeching-squeal noise that is almost like fingers on a chalk board
To point out something on an earlier post, was that 14 AMPS or did you mean 14 VOLTS? Big difference
And alternators don't just 'fail', they can go bad. An alternator putting out 12volts hasn't failed, as it's still doing it's job, just not doing it all that right anymore
Brushes can go as well and cause power issues, but yours is too new for that to happen. Also formula i did mean 14 volts lol sorry i always mix those up. But also that was when the car was just barely started and cold and i usually have the lower volts when it gets hotter and my fans are running. Also when i have my radio turned up fairly loud my volt gauge bounces with the bass in the music sometimes well below the center line on the gauge. So who knows i might need a new alternator and ps pump. Damn these maintenance items lol.
Also can anyone tell me if im ok getting the 140 amp alternator or is that to much for my stock car? should i get something like the 124 instead? i was told that if the wires cant handle the amprage then it could burn up the wires.
Also I forgot to re-add to my post that Alternators DO go bad, and not always just flat out fail. If you've ever seen an alternator putting out 10volts, that sure as hell looks like it's working to me. Working correctly? No, but it's working, doing it's roll of putting out voltage. Fail, to me at least, means it's doing nothing, or has failed catastrophically and seized/exploded. (Mind you exploded doesn't mean kaboom, just **** inside broke apart)
