what power steering pump do i use with the Alternator Relocation Bracket
but, the LS1 pump should be able to be used on the driver side of the motor. My attempt was going to be making a mount and use a piggy back style UD pulley set up, where the UD set would run the Alt and the stock pulley/balancer would run the PS pump, that should be pretty simple to fab up, just have not had the chance.
Maybe an easier set up I have seen is to put a Vbelt pulley on the balancer and change the PS pulley to the Vbelt style too and have the same bracketry that is needed.
I dont think it would be that difficult if you take the time.
Click there, then open the link in that post. That's all the info I was looking for and it should help anyone else looking to keep power steering with a low mount alternator.
https://ls1tech.com/forums/showthrea...tion+speed+inc
