5w-20 anyone?
Old Oct 31, 2008 | 07:19 PM
  #41
Mr. Camaro's Avatar
Originally Posted by buffman
MR camaro have you actually verified these temps with a mechanical gauge after the car is fully up to temps (oil temps in the 180+ degree range)
No, where can I get one? And is it a hassle to check it or is it pretty simple to do? Are the stock ones known to be that "off"? I'm just trying to get close to the proper oil in my car (that way maybe it'll last a little longer, its already up to 170K) , not really trying to get it perfect just as close as I can.
Old Oct 31, 2008 | 07:22 PM
  #42
Mr. Camaro's Avatar
Originally Posted by Formula350
Ya, I read that later post, but it's a moot point in this case. If you're not going to double check everything you say, then don't get mad when people think you've lost your marbles and don't know what you're talking about.
Didnt get mad just trying to make myself clear. Plus I like debating/arguing its how i learn new stuff. I should've been on the debate team or something...
Old Oct 31, 2008 | 11:48 PM
  #43
buffman's Avatar
a lot of times autometer and them sell mechanical gauges. IIRC the Wiki gauge I have setup to test oil pressure was like 25$ and it has a span accuracy of like 1.5% or something. Plus $10-15 in fittings/hose. Generally you can undo the plug in the block above the filter, or if you can get to it you can remove the stock oil pressure sender and plug in there.. Electric sending unit gauges aren't the most accurate, especially stock.
Old Nov 1, 2008 | 07:26 AM
  #44
DADDY&GIRL93TA's Avatar
if it's german castrol send it to me
over here over here
