pros/cons to 1.7 RRs
1.7's will put you close to the edge of the stem...
What did you end up with for a pushrod length, only problem I've ever heard of having with 1.7's was making sure you get the PR-length correct. I have a set of brand new Comp cams 1.7 RR that have been setting in the box for almost 4 years. Never got around to doing the swap from my 1.6 RR comp cams. I would assume you changed the valve springs to something in the .550 range. I think the numbers work out to be .521 lift on a 96 6 spd LT1 stock cam with 1.7 RR. Now I want to put them in the car if your saying you picked up 2mph and 2 tenths, WOW !
IMO you have to swap out the valvesprings and stuff for the 1.6's might as well upgrade to the 1.7's, this is my opinion for the stock camshaft only.
Lift on my stock 96 cam with the 1.7's was .510/.521.
Also, T/A KID. Did you run stock lifters and pushrods when you put your 1.7's in, or did you swap them out for different ones. I've been wondering if I should or not.
I maintained stock stock pushrod length, but just made sure I went hardened. I bought GM replacement valve springs good for .560. I found the part number in a search and got the springs, seals, etc all at one time. Hope this helps.
1.6 or 1.7 roller rockers(alum.for mild and chromoly for racing)
7/16 studs
flat guide plates
hardened .080 wall pushrods
titanium retainers
10* locks
pac 918s(new style) springs
larger rockers ONLY change valve lift which Lt1/4s seem to really respond well to........
) will work fine ? I would think you would want to put a push-rod length checker on the setup. Factory length of stock pushrod is ( 7.20 ? I can't remember ). I have a set of Comp EX-614 springs new in the box ( I believe they are good for .600 lift ) would this be to much spring for the 1.7 RR comp upgrade on my current bolt-on setup ? If this will really add 2mph and 2 tenths to my current time, I like the sound of running a 12.40 @ 111 mph with a stock cam & stock heads full bolt-on car !
besides they dont really have enough seat pressure (105lbs.)you should be looking at a spring with atleast 125lbs on the seat,set up at 1.75-1.80 installed height.
