Who has an MSD Opti?
Old Oct 28, 2008 | 06:53 PM
Cross's Avatar
Default Who has an MSD Opti?
I am starting to think I might not have gotten the timing adjustment set right when i installed mine.
Can anyone tell me the way it should be stock and how you have it adjusted etc?
Thanks
Old Oct 28, 2008 | 07:14 PM
96capricemgr's Avatar
The only way you can verify it will be to measure. Make a TDC mark on the damper, fab up a pointer and check it with a dial back light. Well I guess you could use a damper with the degree marks and then use a standard light, but point is you will have to measure it.
If you still have the stock press fit only damper I would make the TDC mark temporary and assume it has moved and recheck it every time before verifying with a timing light.
