Speaking of 1.7 roller rockers...
http://www.camaroz28.com/forums/show...ht=ls1+rockers
...and it got me curious.
If drilling out the stud holes on stock rockers is the only thing that needs to be done to LS1 rockers to make them fit LT1 heads, do you think it's possible to run LS1 shaft rockers on our heads as well?
(Since studs aren't even involved?)
A set of these would be a noiiiiiiice upgrade:
http://www.byunspeed.com/product_inf...oducts_id=5880
Anybody know if something like this is doable?
I think you missed the point: since the only thing that guy had to do to the stock LS1 rockers to get them to work was drill out the stud holes, and shaft mount rockers don't use studs, maybe it's possible to use them without any modifications?
if the original Ls rockers were modded to fit on Lt heads you should be able to do the same for the RR style. i would definately be checking the pushrod length......
http://74.125.95.104/search?q=cache:...lnk&cd=4&gl=us
Seems like all you'd need to do to run these on a set of LT1 heads is just find the correct size bolts?
