Will this get me low 13's?.........
1. worse traction (lower gearing for first = higher stress on tires)
2. worse traction but making up for it in the top end.
i dont know if that would necessarily be the answer.
pulling the front sway bar would help for sure, but i still argue that some suspension upgrades would be most beneficial. LCA's shocks, TQ arm, etc.
Speaking of breaking the 10-bolt, any moron who is dumping his car at 4500 on a ten bolt is asking for a busted rearend. Nobody ever said it was horrible to slip the clutch through the sixty-foot slightly enough so you don't shock your rearend. That's the reason guys like Fergymoto are making low 12 second passes and leaving pulling the front tires off the ground on a box-stock 10 bolt, their A4 trans put less shock on the rearend. It all depends on your driving style, if you put drag radials on the car it may stay together if your clutch has some slip or you know how to leave.
Believe me, unless you have some factory freak you'll crush the ten bolt on radials leaving hard.
Now there are a ton of guys chiming in saying their making low 13 runs with cat-backs but either it's a "big-fish" story or the weather and everything else in the world was on their side.
TDavanzo Ive put hundreds of runs on 10bolts, havent blown one yet(knock on wood)
With 4.10 and a good clutch = boom
You can come check out my big fish story for yourself. Ran 13.32 yesterday!
With plenty of people to see it!
like i told you before i hope i can get close to that with my altitude & DA i have the mph for a decent pass but 19"radials are not happenin time to go to devcon-2-(16"drag radials)
I know the stall is helping out our 60s but we wouldn't be reaping the benifits of the stall without tires. All the susp mods in the world cant make u hook if u dont have the proper tires.
You have mph for very low 13s if u could get below 2.0 on the 60.
As for the 10 bolt, gotta pay to play.
