Header bolts?
Old Nov 4, 2008 | 08:41 PM
formulabrandon's Avatar
bolts do to back out. between vibrations and heating cooling cycles they can loosen. stage 8 work great. as far as studs take uolts to the hardware store and match the pitch and diam and go slightlylonger.
Old Nov 4, 2008 | 09:01 PM
impaled's Avatar
either studs or ARP or ARP studs if they are out there.
ARP is worth the money as well as locking bolts.
Old Nov 4, 2008 | 09:29 PM
chavez885's Avatar
Originally Posted by buffman
as dwayne already said with new gaskets you have to check the bolts everytime you heat cycle the engine. You may be doing this for up to two weeks after installation. 1" long bolts should be more than sufficient.
Matt
x2, every time u change that gasket you're setting yourself back lol.
