injectors?
Old Nov 4, 2008 | 11:52 AM
LT1SS's Avatar
Default injectors?
when i bought my car it had ford injectors on it. now im camming it so i need to know what size they are. i called a dealer and they said that they went to a 90-93 f-series truck. the numbers on them are: 0280150947 and F1TE-D5A. please help.
Old Nov 4, 2008 | 12:04 PM
Elliott's94Z's Avatar
Well from what it looks like those are 24lb injectors. You don't ness have to change the injectors out with a cam swap if that's what you were looking to do
Old Nov 4, 2008 | 12:15 PM
LT1SS's Avatar
i have a friend that made 330 rws with a similar set up. he had 32 lb injectors. do you think that is too much power for 24's
Old Nov 4, 2008 | 12:19 PM
Nope...I have the stock 24's with a Lloyd cam. I would maybe change them out if you did a head/cam swap or Nitrous kit and were pushing towards the 360 mark
Old Nov 4, 2008 | 12:20 PM
LT1SS's Avatar
cool. thanks for the help
Old Nov 4, 2008 | 12:23 PM
No problem. Unless yours are shot and need new ones I wouldn't waste the money. If you do get a new set look into the Ford red top svo's #30lb
Old Nov 4, 2008 | 12:40 PM
LT1SS's Avatar
how can i test them to see if they are good
Old Nov 4, 2008 | 02:01 PM
1badzee's Avatar
You can run a noid light to see if they are pulsing accordingly and/or hook up an a/f gauge and check if you're running lean
Old Nov 4, 2008 | 02:03 PM
1badzee's Avatar
Hate to get ya on technicality, but they are FMS injectors (Ford Motorsport), the SVO's are the mid-late 80's turbo 4cyl stangs and those injectors are no longer produced. But in the end, doesnt matter what you call it, FMS, SVO, SVT, SN95, blah blah blah they are from our little brother, Ford.
Old Nov 4, 2008 | 02:17 PM
Didn't know they stopped making them...hummm
Old Nov 4, 2008 | 08:27 PM
formulabrandon's Avatar
not to gt technical either but a noid light wont tell you anything about the injectors,it will only tell you if ty are reciving signal from computer. if the ca was running fine when you took them out/ and granted you didnt damage them they are prolly working fine.
