Impala SS pushrod lengths?
Old Nov 5, 2008 | 11:45 AM
Bones Z28's Avatar
Default Impala SS pushrod lengths?
Looking for the correct stock size push rod for an LT1 Impala SS. Reason I ask is because I have that motor in my car (boy was that fun finding out ). Anyways I believe I installed the incorrect size push rods for my car. I installed the 7.200 size, but I think that this is giving me my current problem. The valves are staying open to long and that's why my car is acting up.
But that's my question. Does anybody know the stock size push rod for an Impala SS?
Old Nov 5, 2008 | 12:33 PM
halucinator's Avatar
7.200" are the stock LT1 push rod size.
Old Nov 5, 2008 | 12:56 PM
the_merv's Avatar
Back off the Rockers a little bit, you might have them just a hair too tight.
Old Nov 5, 2008 | 10:43 PM
Bones Z28's Avatar
Thanks for the info, I wonder if I just have the wrong size, (didn't check the length, I know stupid move, this was my first time doing a cam swap). But first I'll checkout if the rockers are too tight, thanks merv.
One more question. When Bauer specd the cam he told me to run the nsa comp cam pro mags. I couldn't because I found out I had an Impala motor with cast iron heads. With that said the rocker studs are press fit so I couldn't install the new 1.6 rr's. So would this **** me up, because I'm running the stock 1.5s instead? The cam is a beefed up cc503 btw, nothing that big. I wouldn't think so but I figure it's worth asking.
Old Nov 5, 2008 | 11:42 PM
buffman's Avatar
shouldn't be an issue with the 1.5s stock rockers. Just have to make sure the correct preload is set for the lifters.
Old Nov 6, 2008 | 11:31 AM
BALLSS's Avatar
cam is not that big so 7.2" should work...better to check geometry to confirm
your lash could also be to tight.
assume you had PCM tuned for cam??
Old Nov 6, 2008 | 10:29 PM
Bones Z28's Avatar
Yes it's just a mail order tune from Madz28 (madtuner) but I went to his place since I'm not that far. It runs a HELL of a lot better than before, idles beautifully and I get clear strong revs since the tune, that's why this is so frickin odd. I think you guys are right tho. Tomorrow I'm going to re adj the rockers to zero lash. I may have over tightened them in the excitement of firing up the car to hear how it sounds. Thanks I'll let you know how things go.
Old Nov 6, 2008 | 10:43 PM
Formula350's Avatar
I hate to make a bonehead (no pun intended) comment, but why not just measure the push rods you took out of the motor for the swap?
Old Nov 7, 2008 | 11:16 PM
Bones Z28's Avatar
Well I'm sorry guys I forgot to update you on that part, that's why it seems dumb. I talked to my buddies yesterday to confirm he did measure and check the rods, and they are fine. I was busy working on another part of the car when they checked it.
Also another update the car pulls real strong. It just needed an adjustment. When I floor it the car pulls like a rape ape. I definitely feel that cam. It's still kinda crappy on regular driving but I think that's just how it's going to be. Not crappy like it's going to die or anything (the idle is real smooth and steady), just some decent vibration in first gear around 15-20mph, but that's probably the cam. Again this was my first cam, I'm not use to such a significant switch. I think I just needed time to get use to it.
Old Nov 7, 2008 | 11:20 PM
Formula350's Avatar
BTW, just to point out, running the 1.5s with having the tune setup for a cam with 1.6s, will leave you lacking a bit of power. Moving to 1.6s will not only gain you the power from less parasitic loss, but the increased lift AND having the tune be much more accurate.
Old Nov 8, 2008 | 10:08 AM
Bones Z28's Avatar
But that's why I explained that I have Impala heads not Camaro heads. The studs can't be switched because they are press fitted into the heads. And with that said I can't switch to 1.6s. I had 1.6 pro mags that I was going to install, believe me it was fun to fine out that I couldn't install them. I'm probably going to take the heads off over winter and take out those press fitted bolts, I just don't have the time right now.
Old Nov 8, 2008 | 11:51 AM
Formula350's Avatar
Yes, I read that, but how does that prevent you from using 1.6s? You could A) Run stamped 1.6s or B) Run self aligning 1.6 RRs.
