LTX Shootout tire specs question.
Old Nov 6, 2008 | 08:20 PM
Tony Shepherd's Avatar
Originally Posted by 93Z2871805
Also, does anyone know the regulation on ballast? The rules for N/A Heads up say 3500lb race weight but they don't say anything about ballast, the NHRA leaves it up to class regulations and say no more than 500lbs of both removable and permanent ballast.
Just add ballast safely and you will be fine. We just don't want to see loose ballast......etc.
Old Nov 7, 2008 | 04:44 PM
93Z2871805's Avatar
Veteran: Air Force
I was going to add ballast as per the NHRA regulations with ballast boxes held in with x2 1/2in diameter steel bolts and fill the boxes with shot bags or lead bars.
