P0100 MAF problem?
Old Nov 11, 2008 | 12:10 PM
Bones Z28's Avatar
Default P0100 MAF problem?
So I have a code thrown that says it's a volume vaccuum leak MAF circuit malfunction. I checked the wiring and all three wires look to be fine from the MAF back to the harness.
I had to adjust my rockers a while back and I noticed that for the passenger valve cover I forgot to reconnect that throttle body hose back into the valve cover. I found it right away tho. I went out did a short blast with the car and saw that code pop up. I reconnected it right away. But now the SES light is still on for that code. I've cleared it and it still keeps coming back. Not sure what's up. MAF looks fine but idk if it is or not.
