Need Gasket Part Numbers
Old Nov 11, 2008 | 11:40 PM
2XR95Z28's Avatar
Default Need Gasket Part Numbers
Hey i was wondering if i could get part numbers for a few things,
1. GM impala Head gaskets
2. LT1 intake manifold gaskets
3. Throttle body gasket
4. Opti-spark seal
5. timing chain cover gasket
6. Crank seal
7. Water pump drive seal
8. Water pump gaskets
also can i re-use my valve cover gaskets?
If ya cant tell i'm doing a cam swap and fixing a blown head gasket and want to bump the compression slightly. Will prolly order all this stuff from summit so part numbers for there would be awesome.
Thanks!
Old Nov 12, 2008 | 10:32 AM
2XR95Z28's Avatar
anyone?
Old Nov 12, 2008 | 10:34 AM
Pampered-Z's Avatar
part numbers listed are for 95 LT1.
The head gasket I listed in called the LT4 .028 gasket, not sure it that's the same as the Imp gasket?
1. LT4 .028 Head gaskets - GM part # 12553160 ( Sold individually)
2. LT1 intake manifold gaskets – GM part # 12524653
3. Throttle body gasket 48/52MM - GM part# 10105379
4. Opti-spark seal – GM part # 12552428
5. timing chain cover gasket – 10128293
6. Crank seal - GM part # 10128316
7. Water pump drive seal GM part # 10217886
8. Water pump gaskets – GM part # 10128343 - need 2 (Sold individually)
9. Vent tube gaskets - GM part # 10108689 - need 4 (Sold individually)
Old Nov 12, 2008 | 11:02 AM
2XR95Z28's Avatar
thank you very much, but what is the Vent tube?
Old Nov 12, 2008 | 12:42 PM
Pampered-Z's Avatar
They are for the coolant tube on the back of the heads that runs up along the passenger sid of the intake. There are 4 gaskets, two on each side. Whenever I do a swap I replace them, they can be reused most of the time, but once everything is back together if they leak they are a PITA to work on, so I just spend the few extra dollars and replace them.
Old Nov 12, 2008 | 02:14 PM
2XR95Z28's Avatar
Thats what i was thinking they we're. thanks again!
