Completely frustrating.
So well the big pain in the *** is that for some reason Summit doesn't have any promags at the GA warehouse. Last weeks came from OH, and now that I had to order another one its even worse, this one is coming from NV! Damn it man! I just want to hear this thing running again, this downtime is depressing.
I'm convinced I'm def. doing a full turn this time. Anyone else running SA promags with the hotcam? I just don't understand why I'm having so many issues. Using the crane double springs, 7.2" pushrods, 1.6 Comp promag roller rockers. The rocker bodies are good, so I was told I don't have geometry issues, that if I did typically the rocker body makes contact with the spring/retainer.
its not the best pic but thats how it should look. you might be hitting the valve retainer
Everything seems to line up fine, I just don't understand why the one on the driver side chewed itself up, only thing I can figure was it was too loose. Maybe I somehow missed it, but I doubt it.
The lifter that came apart was due to the retainer in it snapping in half.
