I think my clutch disc exploded
Old Nov 20, 2008 | 06:34 PM
1994Z28Lt1's Avatar
Default I think my clutch disc exploded *PICS ADDED*
a couple nights ago i was racing my friend's 05 Mustang and in the rare event that i actually miss a gear i missed 3rd on the 2-3 shift, however i didn't go back into first
anyway after i missed the gear i heard the sound from hell as i saw the tach jump above 6k and after that i felt vibration which was pretty bad i thought i threw a rod at first
i got pulled over turned the car off and heard **** flying around coming from presumably the bellhousing and the clutch didn't feel right at all
I restarted that car very briefly after pulling over and as soon as i saw i had full oil pressure i shut it down
My question is how likely is it that my clutch disc exploded at 6000+ rpm vibrated the hell out of my engine and didn't do any damage to the engine?
In a couple days i'm going to tear it apart and i'll have to post pics of the carnage
Old Nov 20, 2008 | 08:14 PM
SoxXpupPeT's Avatar
hmm that sounds possible. could of chipped it or lost a bolt off the flywheel. hope its not as bad as it could be
Old Nov 20, 2008 | 08:52 PM
jarretthise's Avatar
is it stock?? you prolly dont have any puck left!!! could have tore your synchro/s out too!! man i sure hope thats not the case here...
Old Nov 20, 2008 | 09:06 PM
Jditlfm's Avatar
Happened to me. I was messing around with a buddy on a stock clutch and I just straight hit the limiter in second pretty hard and as soon as pushed the clutch to grab third it made a loud bang and the clutch pedal felt real weird and made a whole bunch of noises. The car wouldn't go into gear when started it was all wired. Here is a pic of what i pulled out. That was the first stock clutch i had break, the second broke on spray but just cracked the center hub and had one of those coil springs fall out.
Old Nov 20, 2008 | 09:08 PM
SoxXpupPeT's Avatar
Originally Posted by Jditlfm
holy **** man thats messed up! good thing i changed my clutch! nother to performance but not 140k mile stock
Old Nov 24, 2008 | 12:48 AM
1994Z28Lt1's Avatar
As promised i am following up with some carnage pics from my car the pics are pretty self explanatory let me know what you guys think
A few parts i found in my bell housing
a couple of the bellhousing what do you guys think? Can it be repaired/reused?
Old Nov 24, 2008 | 05:57 AM
wrd1972's Avatar
JB weld that bitch back solid.
Old Nov 24, 2008 | 09:12 AM
Biggin'89's Avatar
damn dude that sucks!
I would get a new bell housing, its already been stressed and probably has fractures in it that you can't see. That would also scare me enough to get a bell housing blanket as well. I don't know about you , but I like having feet, and that could've been much worse.
Old Nov 24, 2008 | 10:01 AM
SoxXpupPeT's Avatar
yeah man you can get that whole welded up. just aslong as there isnt any structural damage to it. other cracked can be V'ed out and welded. if you were in yonkers id weld it up for you
Old Nov 24, 2008 | 12:37 PM
1994Z28Lt1's Avatar
i had a shop take a look at it and they said there wouldn't be any problem welding those holes closed
the bellhousing is actually cracked very slightly in two different areas which the shop also said wouldn't be a problem. Hopefully it wont be a problem, stock bellhousings are hard to find for these cars and im definitely not ready to spend the cash on an aftermarket one right now
Old Nov 24, 2008 | 03:12 PM
1994Z28Lt1's Avatar
would anyone be able to help me track down a part number for my clutch disc? im trying to figure out what brand/model the clutch disc is the #'s are
GM10206759
030594 0752
Old Nov 25, 2008 | 08:43 PM
crookedbowtie's Avatar
F that noise! Get a scattershield, it will be your legs next. I am part of that little club you got going. Blew the clutch disc clean out of my Chevelle. Just broke everything in, had the girl, her father, and little bro in the car. I took it around the block to warm it up, hit the main street and let her have it just about the time the tires stopped spinning in third, the motor kept on going. Luckily I coasted home, but we had to push it up the driveway. Odd being able to leave your car in first and step out side with it running, I don't think the blower or locker had anything to do with it. After I saw that mess I was glad I had a Lakewood scattershield.
Old Nov 28, 2008 | 11:59 AM
Smokeshow_2006's Avatar
Funny, Im pretty sure I shattered mine on wedensday. Although, I really didnt hear any wierd noises, aside from the rev limiter. just a funny vibration. And, a bit of a hijack, any recomendations for a decent, affordable clutch? I probably need to resurface my flywheel too.
Old Nov 28, 2008 | 01:36 PM
Jditlfm's Avatar
I like my spec 2+ but it grabs like a bitch so i would recommend 3.73 gears or more as it gets hard to slip sometimes and more rear end gear would make it easier to take off and launch.
Old Nov 28, 2008 | 03:08 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You went beyond breaking a clutch on that one. You basically shredded it. I wouldn't put a stock clutch back in the car after that happened.
Old Dec 1, 2008 | 08:33 PM
1994Z28Lt1's Avatar
i think i know what caused the clutch to blow under further review
The pilot bushing i believe was stock and had already pregnated all of the oil it was originally impregnated with
the bushing therefore was warn beyond belief with far too much clearance causing the input shaft on the tranny to have a little too much free reign
I dont think i missed third as previously thought, i believe that once i dropped the clutch after hitting third gear the clutch disc contacted the the outside of the pressure plate causing all this mess
anyway new clutch is in, i put in a stock replacement for now since money is an issue, i'll be out of college soon and will hopefully have much more money to mess around with
