Cherry picker position
when you raise the car OR back it up a little as the car raises.
Never done it from the side, It seems a little awkward since you need that space for the
cart holding your motor and trans up. But mine had very long legs, so yours may be different.
before lifting the car up, that way the cart slides out with motor and trans on it.
But yes, it should be on jackstands once you get it high enough.
Smaller hoists are not big enough to extend and lift the car without rubbing.
Mine was a little bigger, I set it to 1.5Ton and cleared without much effort.
I also use a ATV jack under the k-member. It can easily be raised and lowered and I can save the floor jack for under the tranny to balance the load.
I can have a motor out of the car and on the stand in 3.5" hours flat working completely by myself.
