Best way to ckeck opti while on engine?
I just don't want to end up replacing it and find out it wasn't the problem. It's MSD vented on a 96 LT1.
Thanks guys.
Sounds like opti to me however when replaced that TPS it started right away and now I'm bacl to the same point. Could that TPS be just a co incident?
to check the spark pull the number 1 plug wire off and get another plug and put it on the end of the wire and crank your motor....check for erradic spark...if its erradic than your opti is going bad....should be crank spark, crank spark, crank spark not crank, crank spark, crank, crank...if it does that than its goin bad...
could also be your coil
