SS3600 vs PY3400???
Old Nov 23, 2008 | 10:59 PM
JB_97ws6TA's Avatar
Default SS3600 vs PY3400???
I purchased a PY3400 from Dave at Yank and was assured that this was going to be a good matchup for my setup but everyone recommends the SS3600. I looked on the website and it PY3400 is for nitrous or blown applications but what exactly does that mean?? What is the difference between the two converters and how will this thing act just H/C, longtubes, and a couple other bolt ons?
Old Nov 23, 2008 | 11:11 PM
CamaroRacing12's Avatar
i have 0 expirence with the PY series at all never mind the PY3400, but all i can say is the SS3600 has great street manners and is even better at the track! but im sure the PY3400 will be sweet, and u wont be dissapointed... all Yank's products are awesome
Old Nov 24, 2008 | 06:43 AM
LS1 SPEED's Avatar
I would have to say if you told Dave your setup he would put you into the correct converter.
Old Nov 24, 2008 | 06:56 AM
vanilla89's Avatar
I have a py3600 and a ss3600. And the py is noticeably tighter...
Old Nov 24, 2008 | 12:55 PM
JB_97ws6TA's Avatar
what do you mean by "tighter"...
Old Nov 24, 2008 | 02:44 PM
vanilla89's Avatar
Well, the PY flashes to about 3500 and the SS flashed to about 4000. But they drive aroud town about the same.if you plan to spray your car I would run a PY, but for NA I would run a SS or PT
Old Nov 24, 2008 | 03:45 PM
he means better street manners by tighter...
Old Nov 24, 2008 | 05:46 PM
James Montigny's Avatar
The man knows his 'verters.
Old Nov 24, 2008 | 07:59 PM
i def wouldnt argue that, but i will also say hes a busy man.... take that any way u want it...
but his products are the best on the market...
Old Nov 24, 2008 | 08:21 PM
Fair enough, in that case, I suggest that the OP contact the vendor directly
to discuss what he has VS what may be optimal and what the pros/cons are if the difference between the two.
(When I PM Yank, I usually get a response along the lines of "Call Us to Discuss")
SUPER STOCK 3600 4L60E/4L65E LT1
245mm very high stall torque ratio. 3600 stall, 2.50 STR
Lightweight billet cover
PRO YANK 3600 EXTREME 4L60E/4L65E LT1
258mm, Posi Lock-Up Clutch w/Kevlar Linings, 6 bolt mounting lugs , lightweight billet cover, 3600 stall, 2.30 STR
PY has a lower STR, which is going to make for softer launches (VS the SS)
(That also leads to less "slip" at the top end)
PY appears to have more mounting lugs, to handle the TQ burst of an N20 setup.
PY is physically 13mm (1/2") larger in diameter.
The point of a big STR and hard launches is that you give up a little up top, but the gains of your rocket-launch
off the line makes up for it and then some If you were building a street car with limited track time, the PY may
very well have been the best choice.
Old Nov 24, 2008 | 08:54 PM
if ur not spraying her or FI in the future i personally would go with the SS3600, i have it with barely 300rwhp and i love it on the street and track....
all i meant was hes a busy guy and when i called i could tell he was pressed for time.... i believe it is good to talk to him about it but also know or kinda know which one ur aiming at... IMO.... nothing to take away from Yank they are the best...
Old Nov 24, 2008 | 10:28 PM
JB_97ws6TA's Avatar
Thanks for all of your responses guys, I bought the converter directly from yank basically over the phone (it was used but was there for a rebuild when I picked it up) I had a pretty lengthy conversation with dave about it and you guys are absolutely right...the man know his torque converters and his customer service is second to none. The only reason I posted this thread is because most (if not all) recomendations for a yank torque converter usually ends with ss3600. I was just looking to get some feedback from people that have used this converter or know more about it than I do to get a little more info on it. If it was a new converter I am sure dave probably would have sold me something else but it seemed to be a good fit and I couldn't beat the price so I went with it and now your guys' comments just reassured me that I didn't make a costly mistake, thanks!
Old Nov 24, 2008 | 10:51 PM
tell us how u like it! im interested to know!!! im one of those SS3600 generic losers haha
Old Nov 26, 2008 | 04:33 PM
marc97taws6's Avatar
I see everybody is having good times with the SS3600.. so I thought I would get one myself..
Let us all know how the PY runs
Old Nov 26, 2008 | 06:47 PM
JB_97ws6TA's Avatar
I am just waiitng on some gaskets I will let everyone know how it runs. From the look of it I went with a bit of an unorthodox build with the Lunati cam and the PY...not too many ppl go with this set up but for the amount of research I have done on the subject I feel pretty confident. I will post some numbers as soon as I get it to they dyno.
Old Nov 26, 2008 | 08:31 PM
trust me, being different can be very very good
