Lunati Voodoo 270/278
Hydraulic roller, fair idle. Strong power increase in mildly modified engines with excellent throttle response. Will work with stock converter in 383 and up size engines or 2200 RPM stall speed converter in 305-350 cubic inch engines. Likes 3.23-3.73 rear gears. Also the largest cam for inboard/outboard marine applications.
Advertised Duration (Int/Exh): 270/278
Duration @ .050 (Int/Exh): 221/229
Gross Valve Lift (Int/Exh): .515/.530
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-5800
Includes: Cam Only
535/550 1/5's, 231/239 11/106
idles nice at 900rpms, no cam surge, 18" vacuum..
its in a brodix headed 355 with 10:1
if you do a search over at chevelles.com/forums for 60121, you will find many happy ownwers. there is not one unhappy lunati owner over there.
here are a fer videos..
13.6 @ 102 2.25 60'
303whp, 336wtq
i think my heads and tune are holding me back, it should be making atleast 350whp.
aaron
im running brodix IK 180, flow 245 @ 600 IN and 178 @ 600 EX.
i found a formula to figure out what heads you should use based on cam specs, and the 60122 needs a head that flows 248cfm on the intake side. so something that flows over 250cfm would work awesome.
there are guys over at chevelles.com with the 60122 with afr 195's in 383's, and the things just flat out move.
i also think my dual plane holley intake is holding me back, and my carb is still not tuned correctly.
it dyno'd those numbers through a 4spd muncie with a 8.2 10 bolt rear, xpipe and moroso race mufflers.
im actually thinking of sending the heads out to get ported to around a 190cc intake runner.
either cam would work awesome for you, the 60121, and 60122. the cam gear pin comes sticking out real far, and i believe if you need to, you can buy a longer one.
you wont be disappointed with either cam and your heads.
aaron
this is straight from the Designer of the Voodoo line, also designed the Comp XE line, and also owned Ultradyn cams..
From 5000 to 5600 the VooDoo averaged 10 BHP higher that the 264HR.
From 3200 to 4200 the VooDoo averaged 8 ftlbs torque higher that the 264HR.
But the best news was at 2500, where the VooDoo had 30 ftlbs torque MORE than the 264HR. It was 20 ftlbs more at 2800, and 3" more vacuum at idle.
With 9:1 CR, the 270 VooDoo is as big as I would run, and it works with 3.23 RAR.
Computer simulation programs assume that all cams flow air the same way, but they do not. If they did, one company's 300*, .500" lift cam would make power like another's. They don't.
A computer simulation program that gave an accurate Horsepower/torque curve would be similar to those used by the major car manufacturers, and would require the exact cam/valve lift curves, not just a couple of numbers.
UDHarold
Ive alwsy liked lunati cams and Id wish more peple ran them inLT1s.
Only trust rpm ranges when it is an experianced shop specifically stating it is for the LT1.
Looks like it would be worth trying, just like said be prepared to take it to 6300 or so.
