To much compression?
Old Sep 23, 2003 | 03:08 PM
GreekZ's Avatar
Default To much compression?
If I were to install impalla head gaskets and 54cc
heads would that equal to much compression for NA set-up?
No race gas just 94octane
Old Sep 23, 2003 | 05:32 PM
solid95z's Avatar
Default Re: To much compression?
Your compression with that setup (if the bottom end is completely stock) will be 11.157:1 exactly. You will not have any compression issues with that setup at all. I had the Mr. Gasket .026 gaskets with 52cc stock port heads and a stock bottom end and had no issues at all.
Scott
Old Sep 24, 2003 | 04:11 PM
cenman's Avatar
what's the equation to figure out what compression the motor is??
