line locks?
Old Nov 30, 2008 | 06:00 PM
shutzero's Avatar
Default line locks?
are there any line locks that dont need any custom fabrication? i heard that with the abs you need to buy 2 line locks and rig them up to 1 switch?
Old Nov 30, 2008 | 06:06 PM
FASHOOTER's Avatar
I don't have one yet but I heard the SLP kit is a direct bolt on
Old Nov 30, 2008 | 06:14 PM
AChotrod's Avatar
SLP is what came to mind!
Old Nov 30, 2008 | 07:00 PM
z28rob18's Avatar
i just bolted my slp in and that was it
shutzero's Avatar
how hard would it be to bleed the brakes cuz the rest of the install looks super easy
Old Nov 30, 2008 | 07:07 PM
z28rob18's Avatar
not hard just need somone to help pump the brake peddle
Old Nov 30, 2008 | 07:11 PM
Jeff400w's Avatar
Bleeding the brakes is real easy. One person to press the brake pedal and one person to open the bleeders. Takes about 5 mins.
Old Nov 30, 2008 | 07:19 PM
shutzero's Avatar
no need to put the car into bleed mode or anything?
Old Nov 30, 2008 | 07:23 PM
LS1 SPEED's Avatar
SLP is a direct bolt-on and simply bleed the brakes
We have them available with FREE shipping and handling as well.
call # in sig
Old Nov 30, 2008 | 07:30 PM
Jeff400w's Avatar
I have bled mine several times without changing anything. Your only bleeding out a very small amount of fluid for a line lock.
Old Nov 30, 2008 | 07:40 PM
koolaid_kid's Avatar
My SLP kit was a direct bolt on. The only thing I did was change the toggle switch to a momentary switch so it would be NHRA legal.
Old Nov 30, 2008 | 07:44 PM
shutzero's Avatar
how do you change it to a momentary switch
Old Nov 30, 2008 | 08:21 PM
96LT1355Z28's Avatar
You just need a momentary button. I have the B&M line lock. It came with the momentary button, billet bracket to mount the button, and fuse. You just have to bend and flare your own lines. Aslo no you do not need two line locks for ABS cars.
Old Nov 30, 2008 | 08:23 PM
shutzero's Avatar
is there anywhere i could pick the button up at?
Old Nov 30, 2008 | 08:32 PM
Radio Shack, ACE Hardware, they are everywhere. It's just a button that activates when you press it, and deactives when you release it. Just make sure you get the version that is on when pressed, off when released. They come both ways.
Old Nov 30, 2008 | 08:34 PM
shutzero's Avatar
i dont know what the connections on the slp line locks look like but is this something that would fit? http://www.radioshack.com/product/in...ductId=2062496
Old Nov 30, 2008 | 09:30 PM
Jeff400w's Avatar
Any auto parts store would have the button you need. You can crimp on different wiring connectors if you need to.I believe with the SLP kit you dont have to bend any lines.
Old Nov 30, 2008 | 10:04 PM
That's what you want.
Old Dec 1, 2008 | 06:50 PM
Smokinlt1's Avatar
I have the Hurst and had to flare and bend my lines. I got it for $50 nib with lines. I'm running the momentary switch on shifter handle but I'm also running a led toggle switch to let me know the linelock is armed then the big red light comes on when I activate linelock. I did this cause my wife drives the car sometimes and I dont want her or one of her friends accidently hitting the linelock while she's driving the car. U know the "what's this for" and presses button.
Old Dec 1, 2008 | 07:11 PM
shutzero's Avatar
looks really clean...so if i get that button itll hook up to the slp kit?
