rim question backspacing
Old Dec 8, 2008 | 05:48 PM
mike2244's Avatar
Default rim question backspacing
centerline makes a telstar 15x10 with a 7 inch backspacing. has anybody tried this wheel and will it fit? i know i read that 15x10 requires 7.5 inches of back spacing, but if i'm correct the wheels will just stick out 1/2 inch further. they should still fit without any problems?
Old Dec 8, 2008 | 05:53 PM
phantomLT1's Avatar
What size tire you runnin
Old Dec 8, 2008 | 05:56 PM
leadfoot4's Avatar
I thought everybody had caliper clearance issues with 15" wheels??
Old Dec 8, 2008 | 06:03 PM
phantomLT1's Avatar
YEP be prepared to do some grinding OP
Old Dec 8, 2008 | 06:04 PM
mike2244's Avatar
i don't know what size tire yet, i want to buy these but i want to make sure that i am not making a mistake. it really don't matter what size tires because these are going to be my street wheels and whatever tires i go with there not going to give me enough traction to make my rear squat that low to rub the tires. my slicks are mounted on other wheels.
Old Dec 8, 2008 | 06:06 PM
mike2244's Avatar
i have been told that the 15x8 telstars fit with out grinding, with the LT1 brakes. why would the 15x10 rub the calipers
Old Dec 9, 2008 | 07:30 AM
leadfoot4's Avatar
I don't know first hand, but from what I've read here, I believe it's a question of rim diameter, and possibly the shape of the backside of the rim's center, not rim width that is the problem...
