0 reading from o2's???..
Old Dec 13, 2008 | 03:55 PM
grnmonster's Avatar
Default 0 reading from o2's???..
Car was running like crap plugged it in found out that the o'2s had a zero reading on both the front ones (back ones were fine) so i went ahead and exchanged for the second time cause there stilll under warranty plugged the new ones int and still nothing.... what would cause this? there bosch 02's btw
Old Dec 13, 2008 | 04:58 PM
grnmonster's Avatar
bump.....
Old Dec 13, 2008 | 05:56 PM
02NITROUSLS1's Avatar
Check for vacuum leaks.
Old Dec 13, 2008 | 06:03 PM
sweetbmxrider's Avatar
are they fused? pcm problem? burnt wires?
Old Dec 13, 2008 | 06:44 PM
Ralls's Avatar
I'd say there is a break in the signal wire. If you don't see anything visually, check signal voltage at pin 8 for B2S1 and pin 20 for B1S1 at the PCM connector with car at operating temp. Here's a reference http://shbox.com/1/1995_pcm_conn_c.jpg
Old Dec 14, 2008 | 01:11 PM
grnmonster's Avatar
is there an 02 fuse?
Old Dec 14, 2008 | 02:24 PM
i don't think so. it was just a random thought, but no. definitely not.
Old Dec 14, 2008 | 02:25 PM
xx_ED_xx's Avatar
check the grounds as well
Old Dec 14, 2008 | 03:10 PM
Ralls's Avatar
Actually there is a o2 fuse. It's for the heater element though. However, the sensor SHOULD still work even if the fuse is blown IF the car is at operating temperature. All it does is heat the sensor up more quickly. 1993 models don't have heated o2 sensors so that's why I assume it should still work. But that doesn't mean you should over look that fuse.
An o2 sensor creates it's own voltage (no power and ground), so all it has is a signal wire going to the PCM. Check that wire!
Old Dec 14, 2008 | 09:01 PM
grnmonster's Avatar
i will defanatley check that wire....is there a possibilty that the connector that the o2 plugs into could have gone bad??
Old Dec 14, 2008 | 09:21 PM
Ralls's Avatar
Well anything is possible. The connector could be loose or the pins might not be secure. First check fuse 6 in the underhood relay box. Then I would get a volt meter and check the voltage from the purple wire (signal wire). That will let you know if the o2 sensor is giving a signal to the PCM. You could follow the wire and measure the voltage where it connects to the PCM, and you should have the same readings. If not, the wire is broke somewhere. And if you are getting the signal to the PCM but your scanner says there isn't a reading, the PCM has to be bad.
Old Dec 14, 2008 | 09:28 PM
grnmonster's Avatar
Sorry im completely retarded aboout wiring...where is that purple wire...? and the relay box is the one on the drivers side near the front right? wow i feel dumb
Old Dec 14, 2008 | 11:17 PM
it runs from the o2 to the computer on the passenger side firewall. relay box is on the driverside by the intake.
