Damn!
Old Dec 15, 2008 | 01:47 PM
93TAJ.C.'s Avatar
Default Damn!
I was planing on doing a stock bottom ended lt1 build with AI 190cc heads and AI cam, but i dont think ill have the money now. I do have to pull the motor this weekend to replace the pan and front cover gaskets though. So i was wondering what mods would be the best and least expensive. I am thinking headers, pcm for less tune, and a cam, but am not sure what cam makes the best power on a stock headed lt1. I already have comp cams 1.6 rr's and arp studs. Can i use my stock springs with a bigger cam? How much hp will my stock injectors support? I have a 1993 TA so i have the 22lb injectors. How much will a stock clutch hold? Any advise is appreciated!
Old Dec 15, 2008 | 01:52 PM
Javier97Z28's Avatar
You can't use stock springs with a bigger cam.. fuggedaboutit.
Worn out stock clutch doesn't hold much either.
Old Dec 16, 2008 | 09:09 AM
93TAJ.C.'s Avatar
ok, so what cam and springs do you think will make the best power? I will have lt's, tune, and cai o go with it.
