1LE Drive Shaft
I just bought one from a guy in the Classifieds section cause I wanted a back-up Aluminum Shaft incase my LS1 Shaft breaks.
The guy had it on a Car with a 12-Bolt under it, so luckily it came with the 1350 Conversion U-Joint already in it, so all I have to do is bolt it in.
The reason I ask is cause the DS itself is made by Spicer. It's totally different from the LS1 and factory Drive Shafts, it has External Clips for the U-Joints, not the ones that are held in there with the Plastic that is molded in it, and if you upgrade you have to melt them out.
The one I got has a brand new Yoke, and both U-Joints appear to be Spicer Joints, so that's cool, but I'm just wondering how tough they are.
edit: Also some useful info. It didn't use the same universal joints as a stock steel driveshaft or LS1 shaft. They were smaller.
The GM Part Number on it is 10085375, it was originally for a 3rd Gen design, so I wonder if it's a 2.5" diameter like the stock Steel one.
