Trickflow GenX Heads, Compression?
Old Dec 19, 2008 | 02:34 PM
luckyou03's Avatar
Default Trickflow GenX Heads, Compression?
Hey guys I'm home from basic training for 2 weeks and I'd like to finish assembling my motor. It's just a short block right now. I have
Bore size: 4.030"
Rod length: 6.00"
Stroke: 3.480"
Compression height: 1.260"
Dome volume: -3.5cc Flat Top Pistons with 2 Reliefs
My cam is the LE1.6 ( .573/.568 lift )
I'm looking at the Trick Flow® GenX (TM) Street/Strip Cylinder Heads for GM LT1 part number TFS-30400010.
I see that they have 62cc chambers and
Intake Runner Volume (cc): 195cc
Exhaust Runner Volume (cc): 75cc
I've read you need to get these milled to get a good compression ratio. That is fine. I don't have time to wait for a set of ported heads. I know I need to measure piston to deck height, but I don't know how thick of a head gasket I need to get or how much they need to be milled to get the correct chamber cc.
This car will see 99% street time and only a few times at the track. I will be running pump gas 93 octane.
Old Dec 19, 2008 | 09:36 PM
luckyou03's Avatar
I did a little computing and I came up with this:
with the felpro 0.039 head gasket I will get
* Cylinder head Volume (CC) = 62.00
* Piston Top Volume (CC) = -3.50
* Cylinder Bore (Inches) = 4.030
* Cylinder Stroke (Inches) = 3.48
* Piston to Deck Height (Inches) = 0.030
* Head Gasket Thickness (Inches) = 0.039
Compression Ratio is 11.0 to 1
__________
With the impala 0.029
* Head Gasket Thickness (Inches) = 0.029
Compression Ratio is 11.3 to 1
Does this compression ratio sound good? I'm not sure what an ideal compression ratio is.
Old Dec 20, 2008 | 12:59 PM
Abdullah's Avatar
11.3:1 compression looks good.
i suggest you run the AI CNC 215cc TFS LT1 heads (which are originally the TFS 195cc LT1 heads) they are $2,495 from AI http://www.advancedinduction.com also with AI's custom cam and ported
LT1 intake .
or wait for the TFS LT1 21* head CNC'd by AI that will be available by late Jan or early Feb. which what i'm waiting for for my 1996 impala SS.
Old Dec 21, 2008 | 05:55 PM
th3brandon's Avatar
im doing a build now and have these heads...im running flat top piston and going to stay right around stock 10.8.1 or so
Old Dec 21, 2008 | 05:56 PM
CNTLOSE's Avatar
Whatever you get post your results and the price you came up with. I am just now starting to look into heads for my car.
Old Dec 22, 2008 | 09:07 AM
luckyou03's Avatar
Well some of my calculations were wrong from the initial post. I have a 3.5cc piston not a -3.5 so that puts my compression to 10.1:1. So I need to get these heads milled to lower the chamber volume. I am going to call lloyd today and see what compression ratio he recommends for the le1.6 cam.
Old Dec 22, 2008 | 12:25 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
for street duty 11.5 - 12:1 should be fine
