i need help with my opti
Old Dec 23, 2008 | 11:17 AM
superbad's Avatar
Default i need help with my opti
ok lets see whos the smart ones in here.95 t/a, freshtop rebuild, afr 2.05's CC 503,new GM performance timeing gear set ,edelbrock intake,holly T/B,42lbs inj.Bottom is a 355 6000 miles,dyno 415 rwhp .im reaaly happy with the build but just 1 major problem the motor is ripping the cap off of my opti around 4500rpm's? had a harmonic dampener installed and it didnt work??opti is an msd so its not a cheap one .. I really have no clue.. helpp.......ideas???
Old Dec 23, 2008 | 12:24 PM
LM97Z's Avatar
I'll try & help, i'm not too familiar with these cam set-ups, but it sounds like the cam is walking forward for some reason, your going to have to tear it back down & see whats causeing this, the problem wouldn't/shouldn't be in the Dampner, it runs off the crank, but the Opti is run off the cam, so i would say it has to be cam walk, don't know what else it could be.
Old Dec 23, 2008 | 12:25 PM
shbox's Avatar
Did you check the dowel pin length on the CC503? CC sends them out notoriously long. If too long, it puts pressure on the opti drive and forces the rotor into the cap, causing destruction of both.
Old Dec 23, 2008 | 12:56 PM
LM97Z's Avatar
Was thinking of that also, i'll bet thats whats wrong.
Old Dec 23, 2008 | 03:02 PM
RamAir95TA's Avatar
Bingo.
