LT1 engine bay cleanup
Old Dec 26, 2008 | 05:04 PM
F3RR3T's Avatar
Originally Posted by LS1 SPEED
yeh..it's not for everyone as I mentioned. The kit has a lot of time and cost into the materials used.
sell me the prints. i have the tools to make me one lol
Old Dec 26, 2008 | 06:09 PM
LS1 SPEED's Avatar
maybe for next years X-Mas gift
Old Dec 26, 2008 | 06:23 PM
F3RR3T's Avatar
who knows i may pick one up later if i get this upcoming job. have to do a full install tutorial and review
Old Dec 27, 2008 | 08:10 PM
alconk's Avatar
diffdude..very clean
here is mine...
fuel lines
no a/c
no ABS
ECU relocated inside
battery relocated
our custom alt./ps kit
That looks like a work of art!! How hard is it to remove the ABS and what's involved?
Old Dec 27, 2008 | 09:44 PM
F3RR3T's Avatar
i would like to know this also
Old Dec 28, 2008 | 01:51 AM
Taubr Unit's Avatar
get a line lock and buy 2 new brake lines to bend up. 1 new one from the master to the line lock, out of the line lock to a T fitting that runs to your 2 front lines. The other new line from the master to a coupler that ties in to the rear brakes. Pretty simple if ure mechanically inclined. I have some pretty detailed pics if u guys want um.
Old Dec 28, 2008 | 01:57 AM
F3RR3T's Avatar
i got a line lock already but why is it needed when eliminating the ABS
Old Dec 28, 2008 | 01:58 AM
F3RR3T's Avatar
i would also like to look at the pics
Old Dec 28, 2008 | 02:02 AM
Taubr Unit's Avatar
just makes it eaiser and just good to do while your doing it. It be like changing your oil and not putting a new filter on. Heres a pic, you can see how it route from the master, IN the line lock and OUT to the T fitting for the 2 front brake lines. And the rear is just a cupler fitting. A lot of people say you need a porp. valve but i dont have one and used my brakes HARD city driving on slicks n skinnies and never had one problem with tires locking up. Glad i didnt waste the time and money to put on in.
Old Dec 28, 2008 | 02:37 AM
F3RR3T's Avatar
basically the line lock does the same thing in this situation still (lock up the fronts)
Old Dec 28, 2008 | 07:46 AM
chevy42083's Avatar
Yes. And it isn't needed... it's just a good time to put one on if you ever planned on it. If you don't want a line-lock, then it's a waste of time and money. I never plan on running slicks, I'll never need a line-lock. I can foot brake it just fine.
I used....
http://store.summitracing.com/partde...5&autoview=sku
except I bought the summit branded one (Jegs had one also). Although, it looks like SSBC offers them in various fitting sizes. It has a single in, dual out for the front so you do not need a T-fitting.
I personally want a prop valve no matter what, cause I'll be running different brakes and want the adjustability and to be able to tune it for road racing/AutoX.
EDIT: The prop valve I linked is a dual inlet, dual outlet.... not sure if that's a typo. Mine was dual inlet (front/rear), and three outlets (Front Right, Front left, Rear). Looks like they may be expanding their line... they only offered a few when I was looking.
Old Dec 28, 2008 | 10:40 AM
  #32
ks my ss's Avatar
you only need a single in and single out prop valve. just put it in the rear brake line to turn the pressure up or down.
Old Dec 28, 2008 | 10:46 AM
  #33
LS1 SPEED's Avatar
yes info and pics above can get the job done
I used an SJM kit which comes with lines and you need to cut and flare a couple.
Old Dec 28, 2008 | 02:19 PM
  #34
chevy42083's Avatar
This is true.
I just didn't want to buy and plumb a prop valve and a T-fitting, I thought it would look better all in one unit. Really just personal preference... I mention the valve that I have because most people have never heard of it.
Old Dec 31, 2008 | 02:11 AM
  #35
F3RR3T's Avatar
good info guys
Old Dec 31, 2008 | 02:44 PM
  #36
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
ks my ss, that looks awesome. I like how clean everything is run with the wiring. I'm going to have to try and hide mine when I get my engine in my 93.
Old Jan 6, 2009 | 03:03 PM
  #37
94-lt1's Avatar
these motor pics look great
