braided fuel lines for lt1
here is a pic I found with a quick search : lethal93ta
http://cgi.ebay.com/ebaymotors/CORVE...21110004r37559
The pic was more so for the crossover and not the design. There is a lot going on with the regulator and lines.
can you post a pic of your intake / rails? I still think you could do this cheap and look much better.
EDIT: it looks to me like those Vette rails could work.
quick connects and then some 45's or something back to the drivers side as I have mine done
I wish a had a firm answer on the Vette rails you linked, but as mentioned I think it would work.
The setup pictured feeds in both rails in the rear then into the regulator which then regulates it back to the tank.
this is my guess by the looks of it
those rails are setup in parallel unlike the stockers. the fuel enters the back of EACH rail, exits the front of EACH rail then Y's into the regulator then returns
heres how mine will be
like if you had a garden hose (feed) on full blast going into a connected to a tube (Rails) which had a hole the size of a penny in the end pressure in the tube is gonna be stuck at whatever can get out of that hole (regulator)
lol i hope thats a god comparison
bingo
