Track times! NEED Help!
Old Dec 30, 2008 | 07:16 PM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
Originally Posted by AChotrod
Your leaving alot on the table shifting that low!
yea well im happy that hardly beating my car a 13.1 was what came out. i swear though my car isnt that badass or anything just the track was not prepped at all and my tires werent that great i mean street tires. anything past half throttle was spin lol. i got pissed one time and dumped the clutch and flat shifted and everything pulled a 3.5 60' and ran a 15.8 at like 75 or 80 but my speedo was saying 150 lol in 5th gear (yes i hit 5th in the 1/4 lol just spinning) that was a ***** and giggles run lol
Old Dec 30, 2008 | 08:42 PM
94LS1B4C's Avatar
Yeah i race at national trails, In ohio..... This all started After i put the clutch in.... Awhile back my check engine light was on for a O2 sensor this was during the summer, and periodically The check engine light comes on, but then goes away for about a couple months, Im using a nitto drag radial.
Old Dec 30, 2008 | 08:50 PM
87tpita's Avatar
did you run the setup before the clutch install? The stock knock sensor could be hurting you but even with a timing problem you should still be in the 13s if no traction problems. If it all started with the clutch install then....
Old Dec 30, 2008 | 09:04 PM
94LS1B4C's Avatar
What exactly should my car be running with my setup? I have a best time before and after setup of a 14.50
Old Dec 30, 2008 | 09:08 PM
IronOutlaw's Avatar
You should definitly be deep into the twelves with your set up and some sticky tires.
Old Dec 30, 2008 | 09:12 PM
95 bright teal's Avatar
Definitely in the 12's
Old Dec 30, 2008 | 09:13 PM
94LS1B4C's Avatar
hmmmm I dont get it..... This lt1 is really geting me bumed out...... I thought they had potential
Old Dec 30, 2008 | 09:16 PM
IronOutlaw's Avatar
They have potential, you just have a small problem and need to get it sorted out.
What did the car dyno when you had it tuned?
Old Dec 30, 2008 | 09:20 PM
94LS1B4C's Avatar
The car dyno'd 330 rwhp and 350 torque to the wheels. My volts are low, or seem low anyway, the volt gauge is a little bit below the center hash, oil pressure is a good 15psi at idle, and around 35-40psi 4-6K rpms water temp is a good 170
Old Dec 30, 2008 | 09:22 PM
87tpita's Avatar
you shouldnt get bummed, if the motor put down good #s on the dyno, then its gotta be the clutch and the clutch will kill your time if slipping or not fully engaging, did you smell it when at the track? Just saw your #s,,,, difinetly not 14.5
Old Dec 30, 2008 | 09:34 PM
94LS1B4C's Avatar
No i didnt notice the smell of the clutch, not to be confused with the breaking at end of the track i would drive it around the pits a bit to make sure
Old Dec 30, 2008 | 09:39 PM
  #32
3DFORMULA's Avatar
Don't get bummed, something is wrong and you are at the right place to get help.
Old Dec 30, 2008 | 09:44 PM
  #33
94LS1B4C's Avatar
Awesome board to be apart of, Thanks for all the help so far! Much appreciated! I always verd away from the site because of the LS department, so i thought i would try it anyway.
Old Dec 30, 2008 | 09:48 PM
  #34
C_Rules's Avatar
i see you also said this happened after you installed the clutch. don't know too much about manuals to be of any help with that. were you faster before the clutch? if so thats may be the culprit. a stock lt1 runs a little quicker than what you did so there is definitely a problem somewhere.
also get datamaster and the aldl cable and log the car with a laptop if you have one. download it you get 20 free logs. you may have a lot of knock. my car felt strong even with the knock. if traction was a problem i would think you would at least have a higher mph. yours is pretty low. another thing is that cc306 is a pretty big cam. how are your springs?
Old Dec 30, 2008 | 09:54 PM
  #35
94LS1B4C's Avatar
As for the springs, They are the behive springs, They are about 4 years old along with the cam, I bought the car with this setup, and i wasnt able to run the car prier to the new setup, the only thing i did was the clutch. The heads have been milled i think its .0010 i dont own a lap top so i cant really log any info.
Old Dec 31, 2008 | 10:42 AM
  #36
C_Rules's Avatar
okay so you don't know what it ran before it had the clutch so we can't assume that the clutch is the reason its running so slow. how long ago was it dyno tuned?
knock will kill your times and the car will still feel strong. mine felt mighty healthy even 8 degrees of knock. its like a silent killer.
have you checked your springs 4 years with a cc306 on beehives can put some real wear on the springs.
shifting at higher rpms will get you better times. that cam has a high rpm range (i believe 6800) but you have to make sure your valve train can handle it before spinning it that high. shift it at like 6000 to play it real safe and see what times you come out with.
Old Dec 31, 2008 | 10:53 AM
  #37
IronOutlaw's Avatar
I would think he would notice the clutch slipping so i doubt thats it. Get an lt4 knock module and go run and shift around 6300-6500 RPMs.
Old Dec 31, 2008 | 12:45 PM
  #38
C_Rules's Avatar
i bought an LT4 KM and it didn't do anything but it's worth a shot anyway. if he's getting knock its most likely due to his burst knock tables which will need to be modified. i had knock for like 2 years. finally got rid of it when i started to get into tuning. it was due to the burst knock tables. i didn't have to desensitize the sensor at all just had to modify the burst knock tables.
Old Dec 31, 2008 | 04:10 PM
  #39
94LS1B4C's Avatar
The car was dyno'd after the cam install about 4 years ago..... So would i have to take the car to a tuner and have it tune'd after the new LT4 knock sensor is put in?
Old Dec 31, 2008 | 04:23 PM
  #40
chevy8806's Avatar
Originally Posted by 94LS1B4C
My car..... 94 Z M6 LT1 cc306 With dyno Tune, Stock Heads, Hooker Headers, Full Hooker Exhaust, 4:11 Gears, 60' was a 1.9 1/4 was 14.50 @101
All you need is a better clutch, some drag radials, and a DRIVER MOD!!!! Haha John jk
