engine running way rich.
the first time, i had the EGR, AIR, VATS, deleted, shorty headers, 160* stat.,high flow cat. it seemed to run fine like that...except for the lifter.
after i changed the lifter, i got another tune at the same time. same as above, except with Smog and A/C codes deleted and the power tune option (91 octane). now it runs so rich, the car will die after about 15 minutes of ideling.
i changed the O2's with AC Delco's and changed the plugs with new TR55's. changed the fuel filter and the temp. sensor. it still runs this rich.
nothing has been changed inernally on the engine. FP has always been a Walbro 255.
also, the fans don't kick on. i took the temp up to 224 or so and still no fans. there aren't any codes and the fans turn on when i check for codes.
it was a mail order tune from Ion Soltan (Madtuner i believe).
what should i check now?
Also check the intake elbow to the throttle body and make sure there are no tears or rips.
there aren't any exhaust leaks...everything is welded except for the collectors, and i checked those when i changed the O2's. the intake is good also. it's a k&n CAI. i took it out when i took the intake manifold off, then put it back in. i'll double check it anyway.
thanks for the replies.
i changed the sensor yesterday, disconnected the battery, reconnected it and tried again. still rich. i'm not sure what the vlotage going to the sensor should be, but i got 1.27 volts in "run". the third gen ref. voltage s/b 1.7 to 1.9 volts.
the computer is a '93 OBDI. i've never messed with scanners or tuners before, but i think i'm about to.
i'd love to get a real tune, but i'm hours away from the closest place to do anything...which is the reason for a mail order tune. also, i didn't think a lot would be different since it's basically a stock engine.
i'll check the fuel pressure and see where that takes me.
i have a question though. the program i'm using is Tunerpro RT. when at operating temp, the ECM temp sensor is reading about 105 C to 107 C (roughly 221 to 225 F). the temp. gauge is reading about 160 F. the fans turn on at 80 C or so...which is right, but it's no where near that on the temp gauge...it's a little over 100 F.
why is this? i believe the temp gauge on the cluster is pretty accurate, since the stat is a 160* and that's about as hot as it gets, since both fans are on. so i'm lead to believe that the fans are turning on way before the stat is open...but at the right temp that the ECM says.
could the ECM temp sensor be that much hotter than the gauge temp sensor?? what voltage should i be seeing at the wires going into the ECM temp sensor with the car off and key in the "on" position?
lol, sorry if i mislead you...
this is while the car has been sitting for a long time...i believe that the engine temp sensor should be close to what the IAT sensor is reading if the car is not and has not been running. but 27*C more is too much. the coolant isn't warm at all...it's cold. so, reading 48*C (118*F) is incorrect...because of this, my fans are on before the stat is open...and when the car is really 160*F, the computer thinks its 225*F.
