lt1 acting strange please help
Old Jan 8, 2009 | 09:56 PM
rspears9's Avatar
Default lt1 acting strange please help
car was running good today,until i started it back up,its like its viberating at low speed then as you get going does ok,but car doesnt seem to run at its peak.car starts good,all gauges show good,it has a bigger cams and lopes.but seams to lope sloppier now
car is also automatic.has 2300 miles on complete rebuild balanced and blueprinted..
Old Jan 13, 2009 | 01:04 PM
Superbeasst's Avatar
Check list:
ignition wires loose or cracked?
Opti vent harness/vacuum lines plugged in properly (one from opti to intake elbow and one from opti to intake manifold)?
Spark plugs tight?
Mass Air sensor plugged in properly?
Old Jan 13, 2009 | 01:17 PM
ss.slp.ls1's Avatar
bigger camS JK
Any codes?
Old Jan 13, 2009 | 02:38 PM
the_merv's Avatar
Veteran: Air Force
Sounds like a Wire melted to a Header..
