timing set
Old Jan 11, 2009 | 08:33 PM
jdog_kustoms's Avatar
Default timing set
what is the best timing set to run on a 97 lt1 with ewp and still use the crank position sensor
Old Jan 11, 2009 | 09:11 PM
ABA383's Avatar
For the majority of us the stock timing chain is plenty strong...I have an EWP and still use the stock timing set. There's been guys in the 9s using stock timing sets.
--Alan
Old Jan 11, 2009 | 09:19 PM
motor has 50000 on it should i replace gears also
Old Jan 11, 2009 | 11:35 PM
shbox's Avatar
If you think the chain wears without the gears wearing, you are kidding yourself. No sense in replacing one without the others, IMHO.
Old Jan 12, 2009 | 12:18 AM
Elliott's94Z's Avatar
+2..Replace them both with new OEM parts.
Old Jan 12, 2009 | 09:42 AM
ss.slp.ls1's Avatar
+3 on replacing the whole timing set with a stock replacement.
Old Jan 13, 2009 | 10:49 AM
thanks for everyones help
