Ram-Air vs Cold Air Intakes
I think a LS lid and FTRA/SSRA setup would rival the LT WS6 setup. It would be interesting to see results if you could test the two head to head. I know the LS setup isnt as good as the LT but a properly sealed LS setup should be pretty close.
Not only that! After a drive during the summer if you touch the filter area its cold! CAI gets enough air but it doesnt have a ram effect on the top end the routing is not even close to straight and its alot warmer since its in the engine compartment and not sealed to the out side.
Anyone that says .1+ is not worth it, must not be competitive at all. I know if I lost at the track to anything by a tenth, Id be pissed and try to figure what I could do to win next time.
i had seen a picture somewhere amongst the internet that some guy (with no AC) had piped his intake straight and had cut a hole in his radiator support and had put a flat style filter (new vette's) in front of his radiator. it looks like a really good spot. you could just see the filter behind the hood mechanism. you could always try to make something custom like that. i would if i didnt have my K&N CAI. either which way anythings better then stock :p
