Temp sensor in driver's side head.
Old Jan 17, 2009 | 11:59 AM
the_merv's Avatar
Veteran: Air Force
That's like how the 1998 LS1's do it. I never knew you could adapt one for the LT1, good stuff. Then you could use the broken Sensor to plug the Head.
Old Jan 17, 2009 | 02:32 PM
HoLLo's Avatar
Exactly. My broken sensor is just plugging my head haha.
Quoted from that site:
Black=PCM sensor ground
Yellow=coolant signal to PCM
Dark Green=to Gauge
Old Jan 17, 2009 | 05:11 PM
Formula350's Avatar
I suppose with knowing the black, it really wouldn't matter which wire went to which reader (computer/gauge) would it?
Old Jan 17, 2009 | 09:14 PM
I8ASaleen's Avatar
Alright everyone just fyi, I took the advise to ask for the temp sending unit and they had one in stock right away. If your's breaks in the driver's side head it's a temp sending unit to local parts stores.
Old Jan 17, 2009 | 09:50 PM
Formula350's Avatar
^_^ I worked for a parts store heh That, and I just knew it wasn't a sensors based on the difference of a Sensor and Sender Glad you got your mongrel!
Old Jul 5, 2016 | 08:19 AM
Vincent S's Avatar
Hey i have a 1990 chevy truck with a 350 my temp gauge always has read hot so i replaced the temp sensor, the one that screws into the side of the driver side head, the new sensor comes with 2 wires , i screwed it in, the guy at parts store told me to ground the second wire to the block, so i did this, i turn key on first time since i owned the truck i saw temp gauge go from hot, to cold then back to hot,, now when truck gets to idle speed or warms up my check engine light comes on, ,, i am thinking he gave me the wrong sensor,, my old sensor had one port for the one wire,going to it any suggestions?
Old Jul 5, 2016 | 08:50 AM
fex77k's Avatar
You can find a one wire at the parts stores.
Old Oct 30, 2018 | 03:30 PM
Alex-chevy's Avatar
Originally Posted by shbox
The head sensor is one prong. Get it from the dealer. All the aftermarket places seem to get it wrong.
The water pump sensor is 2 prong.
They are both called sensors in the GM parts book.
Do you have a part number for this one prong sensor?
RhThank y
Old Oct 30, 2018 | 04:16 PM
BALLSS's Avatar
RhThank y
If its for the temp gauge (sensor on head) and uses this plug: (one wire)
https://www.rockauto.com/en/moreinfo...049701&jsn=581
Than its this sensor;
https://www.rockauto.com/en/moreinfo...049701&jsn=462
Old Oct 30, 2018 | 04:19 PM
Alex-chevy's Avatar
You are officially the man!! Thank you so much!!
Old Oct 30, 2018 | 04:55 PM
BALLSS's Avatar
That sensor, plug and single wire take a beating from heat from exhaust/engine. The sensor had a heat shield sleeve over it and the wire for connector had at least grey stripe split loom and/or also covered with heat wrap tube.
After 22 years my connector got brittle and broke and the wire was VERY heat fatigued so bought the pigtail and spliced it in and used heat wrap tube I got at Summit to go over that wire
Old Oct 30, 2018 | 09:30 PM
  #32
shbox's Avatar
RhThank y
You could have looked on my website. Info for both is there.
Old Oct 31, 2018 | 05:42 AM
  #33
Alex-chevy's Avatar
I've gotten a lot of good advice from you. I just kinda waited to the last minute to try to figure this one out.
