found problem with engine shake and miss
Old Jan 17, 2009 | 10:58 AM
rspears9's Avatar
Default found problem with engine shake and miss
the cause of the low rpm miss was a broken exhaust valve spring,car runs like a charm once again
Old Jan 17, 2009 | 11:16 AM
96capricemgr's Avatar
Now you need to figure out the cause of the broken spring, if you don't the next one could take out the whole engine.
It is possible for a broken spring to leave you with little left but one head(the other side) and the intake for good parts.
Possible it was just a freak failure but you still need to investigate further. Are the springs really appropriate for the cam? How old are they? Are they setup right?
Old Jan 17, 2009 | 12:00 PM
the_merv's Avatar
That will throw some things off..
Old Jan 17, 2009 | 12:10 PM
rspears9's Avatar
the engine was complety redone with forged internals,but the comp cam and hi-crane roller rocker lifters was installed,we did change the cam bearings,but the springs,i dont know if they are the original stock which would have 128,00 miles on them.or what.
