Bleeding Brakes Help
Old Jan 19, 2009 | 05:01 PM
Badazz 97 TA's Avatar
i was going to say master cylinder.
i too, all of sudden had my brakes go bad one day. but the pedal was real hard and the car did not want to stop at all. but the problem went away the next day AFTER i bought a new brake booster
Old Jan 19, 2009 | 05:59 PM
nik1703's Avatar
what is this brake booster you speak of? :shifty
Old Jan 19, 2009 | 06:10 PM
infinitebird's Avatar
It's the large black thing behind the master cylinder.
Old Jan 19, 2009 | 06:16 PM
nik1703's Avatar
Ah i see. so what do you guys suggest? upgrade brake booster? Replace master? or replace all calipers?
Old Jan 19, 2009 | 06:29 PM
its not going to be the booster. sorry for the confusion of my post.
just make sure none of the brake lines are leaking. if the pedal is soft its most likely the master cylinder. when you pumped the brakes(with the engine off) did the pedal stay hard?
Old Jan 19, 2009 | 06:31 PM
nik1703's Avatar
the pedal has the same pressure as it always did, it just doesnt have the effect. i have to push down super hard to get it to stop the car.
Old Jan 19, 2009 | 06:37 PM
then it sounds like the problem i had. it feels like the brake pads just dont have any clamping force no matter how hard you push on the pedal, correct?
then its probably the booster
Old Jan 19, 2009 | 06:38 PM
nik1703's Avatar
interesting.. how much was it for the booster and where did you get it? is it an easy swap??
thanks!
Old Jan 19, 2009 | 06:48 PM
i got mine from autozone. it was like $80 bucks. plus another $40 for a core charge. i still have mine.
i never put it in because the problem just went away the next day.
Old Jan 19, 2009 | 06:53 PM
nik1703's Avatar
yeah, my problem is not going away. Do you guys think i should get a new booster? or?
Old Jan 19, 2009 | 11:44 PM
nik1703's Avatar
you only got a 13 1/4th mile with a hotcam kit and all those other bolt ons? shouldnt you be doin' 12's?
Old Jan 20, 2009 | 05:54 PM
  #32
nik1703's Avatar
is there any way of determining if its the master cyl or the brake booster?
