solid roller guys?
Old Jan 21, 2009 | 11:44 AM
OutlawZ's Avatar
I run redline race oil....... great stuff.. pricey but great...
Old Jan 21, 2009 | 03:08 PM
FASTFATBOY's Avatar
I run the Rotella because it has about the most Zinc you can get in an off the shelf oil. Its anti wear package is formulated for diesel engines that run high boost and high loads.
Last time I pulled mine down after the NOS mishap it all looked great. In a few more miles I will swap to synthetic Rotella.
Old Jan 21, 2009 | 05:11 PM
1redta's Avatar
Default re
the zinc/ additive package is the shiznit for anti wear.
Old Jan 21, 2009 | 06:59 PM
FASTFATBOY's Avatar
Originally Posted by SLawson86
^^ whats that got to do with solid roller?
The most common failure in a solid roller application is the lifter itself. Whatever you can do to help this, do it.
Oil companies started taking zinc and phospherous out of oils a few years back because it was contributing to emission problems and catalytic converter failures. They did it quietly, Cam companies started have ALOT of solid flat tappet cam failures because of it. Solid rollers also suffered some. Cam companies started including a Zinc additive OR said in the instructions for break in to include a Zinc supplement such as GM's EOS(No longer made) For their flat tappet cams. But Comp Cams puts out there own supplement now.
Higher Zinc content will only help an engine live, all parts of the engine.
Go here and make yourself crosseyed.
www.bobistheoilguy.com
Read this
http://www.highperformancepontiac.co...oil/index.html
Old Jan 21, 2009 | 07:35 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Many people think anti wear additives are only important in flat tappet cams.
It is important for rollers as well.
Just to clarify, GM EOS is available again, but it is now called assembly lube instead of an oil additive so people are not encouraged to use it in their emissions controlled cars.
Old Jan 21, 2009 | 07:40 PM
FASTFATBOY's Avatar
Thanks Lonnie I was not aware of that.
Old Jan 21, 2009 | 08:02 PM
SLawson86's Avatar
Not referring to your post, i guess he deleted it. something alone the lines of whats included to swap a TH400... oops, deleting mine now.
Old Jan 21, 2009 | 08:42 PM
z28rob18's Avatar
so after the build i should start using these additives? because i wont have money to rebuild it lol
