How to unplug harness on opti?
I am trying to determine if my opti or the wiring to it is bad and need to disconnect the electrical harness. Is it possible to remove the connector without tearing everything apart? I can see the connection on top of the opti, but there is no way I can even touch it, is there a trick to unplugging it or am I going to have to tear everything apart to look at it?
Its a 1993 Formula A4 w/ vented opti
Thanks
Thanks
Thanks
Thanks
http://grizzly.com/images/pics/jpeg288/h/h0444.jpg
I figured it out, I took a clothes hanger and bent it so i could slide it around the clip and just eased up on it and it came loose. The inside did have some cooper colored streaking on it so I sprayed everything down with electrical cleaner and will see if that works. The wiring itself looks good and tests ok, so we will see what happens.
Thanks!
Thanks!
