help!
Old Jan 28, 2009 | 01:56 PM
93TAJ.C.'s Avatar
Default help!
Will a 200 trans am steering column work in a 1993 trans am? What has to be the same? Can i switch parts between the two? any help is appreciated.
Old Jan 28, 2009 | 02:03 PM
ss.slp.ls1's Avatar
A lot of parts are interchangeable. I am not sure if the column is a direct swap or not. It will bolt up, but the electronics are what might differ, I wonder if VATS would come into play...
Old Jan 28, 2009 | 07:05 PM
93TAJ.C.'s Avatar
thats exactly what i am worried about, im hoping i can use the parts needed to make it not wig the vats out.
