cutout questions
Old Feb 2, 2009 | 01:39 AM
LT1-Camo's Avatar
very nice...love the stance that hood looks sick
Old Feb 2, 2009 | 03:33 PM
Chrisd000111's Avatar
here some pics the cutout is sort of in between the back and passenger seat, i thought routing the wire to the back seat plug was easier because its one bolt to take the seat out and there is no carpet under there, but make sure the wire is not in front of the cutout i had to use reducers too because the stock exhaust is 2 3/4 and the cutout is 3 inches
Attached Thumbnails cutout questions-dsc00085.jpg   cutout questions-dsc00091.jpg   cutout questions-dsc00092.jpg   cutout questions-dsc00093.jpg
Old Feb 2, 2009 | 03:39 PM
AChotrod's Avatar
here ya go
Old Feb 2, 2009 | 05:06 PM
ss.slp.ls1's Avatar
Originally Posted by AChotrod
here ya go
Yep, that's how you do it.
Old Feb 2, 2009 | 09:22 PM
sorry mine isnt as clean as yours achotrod but i dont have tons of money and have to work with what i have but i was show the placement and where you could run the wire for the electric cutout and the switch
Old Feb 3, 2009 | 02:28 PM
blkZ28mara's Avatar
Where are you guys running your positive wire to?
Old Feb 3, 2009 | 03:06 PM
AChotrod's Avatar
Sorry I didnt see your pics b4 I posted that. I just read the orig post.
If I had tons of money there would be an Elec cut out on there. The cost of ECO was the same as my TDs so I went that route now.
Old Feb 3, 2009 | 05:02 PM
well our placement is pretty much in the same spot but yours looks so much better is that 3 1/2 inch and how much difference did all the suspension upgrades make , and what do you have done to the motor is it a 355 and what cam and exhaust do you have i like the sound of it
But i cant remember where i tapped into for the positive wire i know i didnt go to the headunit cause a local shop told me it would draw to much power when used but i can check tomorow
Old Feb 3, 2009 | 05:06 PM
blkZ28mara's Avatar
Okay thanks
Old Feb 6, 2009 | 03:57 PM
sorry it took me so long to check ive been really busy but i tapped into a thick pink wire which is accessory it is near the fuse panel you have to take the knee panel off and the black plastic piece at the bottom of the dash and its near the fuses i would just get a test light and make sure that it is accesory but mine is make sure its the thick pink and 12 volts
Old Feb 6, 2009 | 06:32 PM
blkZ28mara's Avatar
alright thank you very much
