HSW Micro Controller
Old Feb 7, 2009 | 06:37 AM
gregrob's Avatar
Default HSW Micro Controller
http://www.harrisspeedworks.com/shop...roductid=16983
This work for LT1's?
Also, how do I pull timing out when spraying? Will I have to run all the time in and N02 tune, or is there a "timing tuner" for the LT that can be used only when spraying?
Thanks
Old Feb 7, 2009 | 06:44 AM
z28rob18's Avatar
that controller is fine for an lt1 cuz its a nitrous controller doesnt do anything with the motor. as far as timing how much you gonna spray?
Old Feb 7, 2009 | 11:32 AM
gregrob's Avatar
might start out w 75 shot but you know how nitrous is.
Dont think I'd go over 125 max
Old Feb 7, 2009 | 11:39 AM
z28rob18's Avatar
i dont think you'll need to pull any timing just a set of tr6 plugs and the microedge plus whatever else makes you feel safe
Old Feb 7, 2009 | 11:40 AM
gregrob's Avatar
Gotcha...
If I wanted to pull timing, for whatever reason. What device could I use?
Thanks
Old Feb 7, 2009 | 11:50 AM
z28rob18's Avatar
im not sure but if you ask in the nitrous section they will answer all ur questions and the professionals hang in there
Old Feb 7, 2009 | 11:52 AM
gregrob's Avatar
cool thanx man
