LT4 cam question
). It's a comp XE grind, 236/242 .555/.576 on a 112LS. It made decent power, but I'm in the midst of a rebuild and am talking an alternate route.For a custom grind, head over to www.advancedinduction.com or http://www.elliottsportworks.com. Give either one a call, explain what you have, and they will supply you with the cam best for your application, hands down.
The LT4 acronym only applies to parts that will bolt onto an LT1-shortblock. LT4 parts include LT4 heads, intake, valve covers, valvetrain components (springs, rockers, hardware), and camshaft. So your question "will LT1 heads fit on an LT4" doesn't make too much sense. At least now you know.
LT4 heads will only work with an LT4 manifold, but they will happily bolt onto any LT1 short-block. You cannot use an LT1 manifold with LT4 heads, or vice versa.
There is no such thing as an LT4 bottom end. It is only the valvetrain package. We all had to learn at one point, so no big deal. The LE2 is a good well-matched combo. You will want to make exactly sure of what you're buying. Chances are if the guy you're buying this block from is marketing it as an LT4, he's full of crap.
What, are you asking, is an LT4?
