Best recommended LT1 cam
The sticky at the top is a good place to start reading up.
the hotcam is hated by alot of people but it does put out descent numbers and is a little smaller than the 503.
Personally though, if I dont rebuild my motor this summer and just swap cams Im going with the cc306, its bigger than the above cams and needs to be spun higher to make more power but in the end, it makes more power and it will be goin in my "racecar/toy"
the big cams on stock heads actually run out of steam because they're not designed with the restrictions a stock head will force upon you. as far as power I've seen some gm847/cc306 cars dyno around the same as a cc503 through an auto, not sure with a 6 speed though. can't really say I've seen dyno numbers of a cc503 through a t56 but I imagine it would be around 350rwhp or so
