Intake manifold
Old Feb 19, 2009 | 09:25 PM
93blacktransam's Avatar
Default Intake manifold
ok guys im pulling off the intaketo check out the drive gear for the oil pump and to check out the heads.....what are the steps in pulling the intake and putting it back on what do i need and is it hard ....also im painting it and getting the egr off the back.....
and what kind of paint do i use and all help will be greatly appreciated
Old Feb 19, 2009 | 09:39 PM
myltwon's Avatar
high temp paint
pretty much pulling the intake it just undoing bolts, fuel rail, egr tube, and vacuum lines]
when you put it back on make sure to let the intake set for around a day since LT1s are notorious for back of the manifold oil leaks
Old Feb 19, 2009 | 09:53 PM
anyone have a blue intake or blue under the hood....im doing two tone blue and black on mt camaro
Old Feb 19, 2009 | 10:00 PM
myltwon's Avatar
Old Feb 19, 2009 | 10:25 PM
ss.slp.ls1's Avatar
Follow these...but only where they talk about removing and reinstalling the intake:
http://shbox.com/ci/cam_removal.html
http://shbox.com/ci/cam_install.html
