gm847 cam
Old Feb 22, 2009 | 11:05 AM
SHDY 5.7's Avatar
Cool gm847 cam
Views and opinions needed. Good cam?
Does it make good power?
Good with n20?
Planning out my 2010 set up....
Im thinking ported heads,847 cam,bigger converter,full exhaust,racetronix fuel set up,injectors,and a truck load of n20!!
If I don't go 847,I may go cc306. I hear the 306 works great with with n2o. Oh and I may open the rear end up finally,maybe a 4.10.....
Old Feb 22, 2009 | 11:22 AM
myltwon's Avatar
well if you're thinking heads,cam, and **** ton of nitrous you might want to be thinking about piston, rods, and crank.
imo better grinds are out there but the gm847/cc306 are still stout performers
Old Feb 22, 2009 | 11:42 AM
SHDY 5.7's Avatar
Yeah,custom grinds are fun,but off the shelfs can work to.
Im debating on a set of pistons or just staying safe on the n20.
If im gonna build a bottom end and buy pistons etc. I may put this BBC and th400 I have to good use instead.
Old Feb 22, 2009 | 12:17 PM
robsquikz28's Avatar
do the 847 and ask taubr unit he has had it and knows all about it.....pimp ****
Old Feb 22, 2009 | 12:22 PM
th3brandon's Avatar
i got it in my car with trick flow gen x heads and that damn thing pulls like a mother ****** after 3000rpms and even low end is crazy..i think you will like it alot..some people will tell u its to big put i think its a nice cam with after market heads or a good port job..just my 2 cents
Old Feb 22, 2009 | 01:36 PM
Taubr Unit's Avatar
Yea Dale, had the 847 cam in my car, runs like a raped ape with stock heads. Put on some ported heads and it would really fly.
Old Feb 22, 2009 | 04:47 PM
SHDY 5.7's Avatar
Yeah,I knew u ran it. I know it sounds disgusting!!
What all did u have to change for the 847 jerr?
Anyone else used this cam w/a little n20?
Old Feb 22, 2009 | 04:54 PM
all the matching hardware springs etc...a stall and a gear could and would help
Old Feb 22, 2009 | 04:58 PM
Schweet97Z's Avatar
Im running the 847. Its a good cam...alittle big IMO for stock cubes. It will make power all the way to 7000 rpms. The cam will work well with nitrous. I would imagine your not going to spray anything over a 150 shot on stock bottom end. If you have thought about spraying more then I suggest changing Rod Bolts and going to main cap studs. Im doing that to my motor since I have it out, just for a peice of mind, since im going to be putting a 150 shot to it. If you have anymore questions post em up, and ill try to do my best to answer them. Also nitrous and big stall dont mix. If your going to spray a 150 or higher id stay around the 32-3600 range especially if your going to spray out of the hole.
Old Feb 22, 2009 | 05:29 PM
SHDY 5.7's Avatar
Ill only spray 150 max.
What kinda gains did u notice with the cam?
I know its a big cam,that's half my concern. What are u reving ur car to with this cam?
Thanks.
Old Feb 22, 2009 | 08:42 PM
Schweet97Z's Avatar
I made peak power @ 7000 rpms. I had my shift points set @ 6500. The pcm is limited to 7200. Even on a 150 shot, if the motor is out of the car I would put ARP rod bolts and main cap studs in it just for a peice of mind. Also upgrade the oil pump to a new stock pump or melling m155 w/ the GM white (high pressure) oil pump spring. It makes power and pulls very hard. It will def put a smile on ur face, just realize your going to have to rev high, especially if you have ported heads. Goodluck!
Old Feb 22, 2009 | 09:22 PM
Bersaglieri's Avatar
I'd do the CC306 if you wanted to pump some nitrous in there. Either one will make you happy. xxsaint69x really liked his CC306 with nitrous.
-Dustin-
Old Feb 22, 2009 | 10:27 PM
slomarao's Avatar
if your going n2o go cc306. They have done very well on juice for many years.
3.73,3600 stall, 175shot, slicks........ your movin.
Old Feb 22, 2009 | 10:29 PM
94_formula_lt1's Avatar
ive also heard the cc306 does good with nitrous
Old Feb 22, 2009 | 11:52 PM
Schweet97Z's Avatar
on anything under a 200 shot you shouldnt have to worry much about the cam. just keep the LSA 112* and above the cc306 is a fine off the shelf cam, but what makes it a better nitrous cam over the 847? thats what i want to know....
Old Feb 23, 2009 | 12:46 AM
SHDY 5.7's Avatar
Thanks everybody. I love the sound of the 847!!!!
lifeisgood's Avatar
ok im interested......no on has said the power theyve made with either cam...
Old Feb 23, 2009 | 01:23 AM
Schweet97Z's Avatar
I put down 385 rwhp through a big stall, stock blown up trans (blew rear planetaries day of dyno tune), unported intake, stock injectors, stock throttle body, stock waterpump. Im looking to make around 415-420 rwhp in the new car w/ the same cam and all the above problem taken care of.
Old Feb 23, 2009 | 07:51 AM
SHDY 5.7's Avatar
Wow,those are impressive numbers.
Now,im not going to go nuts on my heads or intake,just basic porting.
To also be truthful,id rather jet the spray down and leave my fuel system alone! Is my stock fuel system enough for the 847?
Im also looking for the same answers with the cc306 if anyone can help.
Dale
Old Feb 23, 2009 | 10:13 AM
Schweet97Z's Avatar
Dale
I got lucky. My stock injectors supplied enough fuel across the board. That being said, I would invest if you have the money. I just ran out.
