Comp custom grind?
Old Feb 22, 2009 | 07:52 PM
clwz28's Avatar
Default Comp custom grind?
I found another comp custom grind on ebay and bought it,I received it Friday (218 int.,228ex. 502 lift int./510 ex.,112 sep.(270/278 adv.).This cam has xe lobes also,I could of bought one just like it with 110 sep. a couple weeks ago,my point is comp. must do alot of custom grinds for people.I will be installing this cam and my stall in the next few weeks,I love the numbers on this cam ,its in beteen a cc502 and cc503,I will post my times after I am done,I also bought a set of isky lifters +isky(235d) valve springs,the guy I got them from said these are the best drop in springs for lt1s with fairly mild cams?
Old Feb 22, 2009 | 09:42 PM
myltwon's Avatar
got a p/n on the springs?
that cam sounds just like a cc503 but with less duration
Old Feb 22, 2009 | 09:49 PM
clwz28's Avatar
235-d isky,they are recomended with nearly all iskys lt1 cams
Old Feb 22, 2009 | 09:59 PM
myltwon's Avatar
do you mean the 235-D? that's the only one I see come up for LT1s on their site
Old Feb 22, 2009 | 11:02 PM
clwz28's Avatar
235-d,yep your right,I am blind its all over the box.
