Injector Question
Old Feb 23, 2009 | 04:26 PM
95greenmaro's Avatar
[QUOTE=96capricemgr;11114024]
MANY high rpm power losses are caused by improper or worn out springs but everyone wants to change everything else first.
QUOTE]
it is a brand new motor. everything was replaced in it. the old motor had 50 thous. eaten off of a lobe on the cam, and he replaced everything when he got the new cam, including the springs
Old Feb 23, 2009 | 04:29 PM
96capricemgr's Avatar
So what, people put the wrong springs on motors every day, even with "professional" help.
Old Feb 23, 2009 | 04:49 PM
Originally Posted by moehorsepower
When you purchase injectors make sure you get the correct impedance or you will need and injector driver...
how do you determine the correct impedance?
Old Feb 24, 2009 | 07:16 AM
moehorsepower's Avatar
All our cars use High Impedance injectors, Usually when you go big, Like I have 85lb injectors I use an Impedance Convertor because at one time all of the larger injectors were low impedance, But even now they have large injectors that are high...
Old Feb 24, 2009 | 07:22 AM
ok, thanks for the info
Old Feb 24, 2009 | 08:13 PM
V10GTS's Avatar
i'd go bigger
Old Feb 24, 2009 | 09:30 PM
GIZMO's Avatar
Originally Posted by 96capricemgr
When folks reccommend an injector ask WHY, the answers will usually center around MARKETING though the person doing the recommending wont realize that is what swayed them.
One of the better statements that I have ever seen on this forum.
